[GRASS-user] v.out.ascii with vector created by v.net.allpairs
Johannes Radinger
johannesradinger at gmail.com
Wed Jan 30 06:28:07 PST 2013
I performed an analysis to get the distances between single points
within a network using v.net.allpairs. As a result a point vector is
created containing following information in the attribute table:
for example
cat,to_cat,cost
1,1,0
1,2,12
1,3,10
2,1,12
2,2,0
2,3,17....
.... so there are actually several lines associated with the same cat
value (of course as
the tool gives all pairwise distances). However, when I try to export the table
into a text file using v.out.ascii only one line per cat is
exported... How can I export
the whole table as shown in attribute table of the vector?
thank you and best regards,
Johannes
