[GRASS-user] unexpected i.pansharpen results
    Yann Chemin
    yann.chemin at gmail.com
    Thu Jan 31 20:06:16 PST 2013
from the code in trunk:
       if sproc:
            # serial processing
            e = '''eval(k = "$ms1" + "$ms2" + "$ms3")
                "$outr" = "$ms3" * "$panmatch3" / k
                "$outg" = "$ms2" * "$panmatch2" / k
                "$outb" = "$ms1" * "$panmatch1" / k'''
            grass.mapcalc(e, outr=outr, outg=outg, outb=outb,
                          panmatch1=panmatch1, panmatch2=panmatch2,
panmatch3=panmatch3,
                          ms1=ms1, ms2=ms2, ms3=ms3, overwrite=True)
        else:
            # parallel processing
            pb = grass.mapcalc_start('%s_blue = (%s * %s) / (%s + %s + %s)'
                                (out, ms1, panmatch1, ms1, ms2, ms3),
                                overwrite=True)
            pg = grass.mapcalc_start('%s_green = (%s * %s) / (%s + %s +
%s)' %
                                (out, ms2, panmatch2, ms1, ms2, ms3),
                                overwrite=True)
            pr = grass.mapcalc_start('%s_red = (%s * %s) / (%s + %s + %s)' %
                                (out, ms3, panmatch3, ms1, ms2, ms3),
                                overwrite=True)
It is a mapcalc process started using Python wrapper lib "grass.script",
the process comes to debug a mapcalc command as described by the expression
"e" initialized at the beginning of the copied code.
Run in it mapcalc with float() casting and see if it is a problem.
On 31 January 2013 23:36, Michael Barton <Michael.Barton at asu.edu> wrote:
>  i.pansharpen uses Python, not Bash. So it is not an integer math
> problem.
>  However, you might try changing your input maps to float or DCELL. See
> if that changes things.
>  Michael
>          ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
>  voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
> www:  http://csdc.asu.edu, http://shesc.asu.edu
> http://www.public.asu.edu/~cmbarton
>  On Jan 31, 2013, at 2:11 AM, <grass-user-request at lists.osgeo.org>
>  wrote:
>  *From: *Yann Chemin <yann.chemin at gmail.com>
>  *Subject: **Re: [GRASS-user] unexpected i.pansharpen results*
>  *Date: *January 31, 2013 2:11:33 AM MST
>  *To: *Hamish <hamish_b at yahoo.com>
>  *Cc: *GRASS user list <grass-user at lists.osgeo.org>
>  hmmm, yes that looks like an old friend to check...
> On 31 January 2013 14:06, Hamish <hamish_b at yahoo.com> wrote:
>>   (sorry for the html,top posting)
>> I wonder if the script is doing integer division when it should be doing
>> floating point division?
>> http://trac.osgeo.org/grass/browser/grass/trunk/scripts/i.pansharpen/i.pansharpen.py
>> Hamish
>> --- On *Wed, 1/30/13, Eric Goddard <egoddard1010 at gmail.com>* wrote:
>> From: Eric Goddard <egoddard1010 at gmail.com>
>> Subject: [GRASS-user] unexpected i.pansharpen results
>> To: grass-user at lists.osgeo.org
>> Date: Wednesday, January 30, 2013, 8:30 AM
>>   Hi all,
>> I'm attempting to pansharpen some ikonos imagery using the i.pansharpen
>> tool in Grass7 on windows 7 installed via OSGeo4W (r54756-478).  The range
>> for the sharpened red, green, and blue outputs are 0-30, which seems
>> suspicious given the 16bit range of the input bands. The command I used was:
>> i.pansharpen.py "sharpen=ihs" "ms3=ik_mss.4 at eric" "ms2=ik_mss.3 at eric"
>> "ms1=ik_mss.2 at eric" "pan=ik_pan at eric" "output_prefix=ik_ihs"
>>  The input bands are linked via r.external, would that matter?
>>  The output from my test area is below. Any assistance would be greatly
>> appreciated.<image.png>
>>  Thanks,
>>  Eric
>>  -----Inline Attachment Follows-----
>> grass-user mailing list
>> grass-user at lists.osgeo.org<http://mc/compose?to=grass-user@lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Yann Chemin
Researcher at IWMI
Skype/FB: yann.chemin
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130201/328e7009/attachment-0001.html>
