[GRASS-user] r.in.wms2: should this work on GRASS 6.4.3RC3?
RichardC
richtcooper at hotmail.com
Mon Jul 1 07:00:01 PDT 2013
I've installed r.in.wms2 into GRASS 6.4.3RC3, but I cannot import a layer.
Here are two examples of output (using different drivers):
r.in.wms2.py url=http://neowms.sci.gsfc.nasa.gov/wms/wms?
layers=MOD14A1_E_FIRE output=MOD14A1_E_FIRE maxcols=398
ERROR: value <WMS_GRASS> out of range for parameter <driver>
Legal range: WMS_GDAL, WMS_GRASS, WMTS_GRASS,
OnEarth_GRASS
Description:
Downloads and imports data from WMS servers.
Keywords:
wms
Usage:
r.in.wms2.py [-oc] url=string layers=string[,string,...]
output=name
[srs=value] [region=string] [wms_version=string]
[format=string]
[method=string] [maxcols=value] [maxrows=value]
[urlparams=string]
[username=string] [password=string]
[styles=string[,string,...]]
[bgcolor=string] [driver=string] [capfile=name]
[capfile_output=name]
[--overwrite] [--verbose] [--quiet]
Flags:
-o Don't request transparent data
-c Get capabilities
--o Allow output files to overwrite existing files
--v Verbose module output
--q Quiet module output
Parameters:
url URL of WMS server
layers Layers to request from map server
output Name for output raster map
srs EPSG number of source projection for
request
default: 4326
region Named region to request data for. Current
region used if omitted
wms_version WMS standard
options: 1.1.1,1.3.0
default: 1.1.1
format Image format requested from the server
options: geotiff,tiff,jpeg,gif,png
default: geotiff
method Reprojection method to use
options: near,bilinear,cubic,cubicspline
default: near
maxcols Maximum columns to request at a time
default: 400
maxrows Maximum rows to request at a time
default: 300
urlparams Additional query parameters for server
username Username for server connection
password Password for server connection
styles Styles to request from map server
bgcolor Color of map background
driver Driver for communication with server
options: WMS_GDAL, WMS_GRASS, WMTS_GRASS,
OnEarth_GRASS
default: WMS_GRASS
capfile Capabilities file (input)
capfile_output File where capabilities will be saved
(only with 'c' flag).
2.
layers=MOD14A1_E_FIRE output=MOD14A1_E_FIRE maxcols=398 driver=WMS_GDAL
File "/home/rcooper/.grass6/addons/r.in.wms2.py", line
230, in <module>
sys.exit(main())
213, in main
from wms_gdal_drv import WMSGdalDrv
ImportError: No module named wms_gdal_drv
Any ideas how I should proceed. Will also test on GRASS 7.
Cheers,
Richard
Linux Mint 13 (ubuntu Precise)
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-in-wms2-should-this-work-on-GRASS-6-4-3RC3-tp5063334.html
Sent from the Grass - Users mailing list archive at Nabble.com.
