[GRASS-user] r.in.wms2: should this work on GRASS 6.4.3RC3?
Štěpán Turek
stepan.turek at seznam.cz
Tue Jul 2 06:49:10 PDT 2013
Hi Richard,
Please in G7 try:
r.in.wms url=http://neowms.sci.gsfc.nasa.gov/wms/wms layers=MOD_LSTD_CLIM_E
output=MOD_LSTD_CLIM_E format=png
Implicitly format is set to geotiff, however this server does not provide
it.
Also you can try WMS in WxGUI [1] in G7, there you get only options which
server supports. After r56978 G7 should also support CRS:84 projection code,
which the server uses for WMS 1.3.0.
Best,
Stepan
[1] http://grasswiki.osgeo.org/wiki/WxGUI/Video_tutorials#Add_web_service_
layer
(http://grasswiki.osgeo.org/wiki/WxGUI/Video_tutorials#Add_web_service_layer)
---------- Původní zpráva ----------
Od: RichardC <richtcooper at hotmail.com>
Datum: 2. 7. 2013
Předmět: Re: [GRASS-user] r.in.wms2: should this work on GRASS 6.4.3RC3?
"I installed xml2 and can now partially run r.in.wms from the Command
console,
but it appears to get stuck calculating tiles:
r.in.wms output=MOD_LSTD_CLIM_E
mapserver=http://neowms.sci.gsfc.nasa.gov/wms/wms? layers=MOD_LSTD_CLIM_E
format=geotiff maxcols=1024 maxrows=1024 method=nearest
Calculating tiles
I can see a 0 byte file in the LOCATION's .tmp directory.
In GRASS7 I can download the capabilities document, but not any layer,
running from GRASS' Command console in the Layer Manager.
This outputs the capability document: r.in.wms -c
url=http://neowms.sci.gsfc.nasa.gov/wms/wms?
The following gives an error:
r.in.wms url=http://neowms.sci.gsfc.nasa.gov/wms/wms? layers=MOD_LSTD_CLIM_E
Downloading data from WMS server...
ERROR: Unable to fetch data from:
'http://neowms.sci.gsfc.nasa.gov/wms/wms?&'
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-in-wms2-
should-this-work-on-GRASS-6-4-3RC3-tp5063334p5063479.html
Sent from the Grass - Users mailing list archive at Nabble.com.
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user"
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130702/bed1d238/attachment.html>
