[GRASS-user] handling raster resolution with r.reclass
Chiara Scaini chiara.scaini at bsc.es
Tue Jul 2 10:23:20 PDT 2013
Hello!
my name is Chiara, I'm currently using grass to postprocess netcdf data
and peroform spatial analysis
I import netcdf bands separately, then reclassify the values (with
external tables) and finally convert the area that i'm interested in
into polygons.
while using r.reclass, the output raster has a lower resolution that
the initial one. this parameter does not seem to be customizable. Of
course I could change the resolution afterwords, but it would imply an
interpolation, while the values of the initial raster are more
reliable...
how could I solve this problem?
thanks a lot!
WARNING / LEGAL TEXT: This message is intended only for the use of the
individual or entity to which it is addressed and may contain
information which is privileged, confidential, proprietary, or exempt
from disclosure under applicable law. If you are not the intended
recipient or the person responsible for delivering the message to the
intended recipient, you are strictly prohibited from disclosing,
distributing, copying, or in any way using this message. If you have
received this communication in error, please notify the sender and
destroy and delete any copies you may have received.
http://www.bsc.es/disclaimer
