[GRASS-user] handling raster resolution with r.reclass
Chiara Scaini chiara.scaini at bsc.es
Wed Jul 3 01:39:29 PDT 2013
Hi all!
and thanks Alex, Nikos and Glynn for the reply
yes, setting the g.region, all the raster have the same resolution of
the netcdf band!
problem solved :)
thanks
Chiara
On Wed, 3 Jul 2013 03:10:18 +0100, Glynn Clements wrote:
> Chiara Scaini wrote:
>> while using r.reclass, the output raster has a lower resolution that
>> the initial one. this parameter does not seem to be customizable.
> A reclass map always has the same bounds and resolution as its base
> map. It cannot be otherwise, as a reclass map is simply a table
> listing the mapping between categories.
> However, with few exceptions, GRASS modules which read raster maps
> automatically resample them to the current region. See the g.region
> manual page for details on displaying and changing the current
> region.
WARNING / LEGAL TEXT: This message is intended only for the use of the
individual or entity to which it is addressed and may contain
information which is privileged, confidential, proprietary, or exempt
from disclosure under applicable law. If you are not the intended
recipient or the person responsible for delivering the message to the
intended recipient, you are strictly prohibited from disclosing,
distributing, copying, or in any way using this message. If you have
received this communication in error, please notify the sender and
destroy and delete any copies you may have received.
http://www.bsc.es/disclaimer
