[GRASS-user] Overlaying vector with raster-computational problems
Moritz Lennert
mlennert at club.worldonline.be
Tue Jul 9 07:28:23 PDT 2013
On 09/07/13 16:04, Paolo Ruzza wrote:
> Thanks for the suggestion, but if I think that if I follow the procedure
> which you have indicated I will only be able to partially solve my
> problem. What about those parts of the polygons that are not boundaries?
> These might well overlap with certain cells of the raster grid...
Maybe in two steps:
- First use v.to.rast to transform the polygons to raster at current
resolution. This raster will have null pixels for very small islands.
- Then use the v.to.points solution to also catch those pixels with
small islands.
- Then r.patch to put the two together.
Moritz
> thanks,
> Paolo
> 2013/7/9 Moritz Lennert <mlennert at club.worldonline.be
> <mailto:mlennert at club.worldonline.be>>
> On 09/07/13 13:21, Paolo Ruzza wrote:
> Dear GRASS users,
> I am confronted with a "non-standard" problem and I would
> appreciate any
> help that you can give me. I have several vector files
> (polygons) and an
> arbitrary raster grid, only with category numbers associated to
> it. I
> would like to overlay the vectors onto the raster grid in order
> to query
> it and extract the categories of the raster grid which overlap
> with the
> polygons of each vector file. I am not interested in getting any
> info
> from the vector polygons, I just want know where the vector and the
> raster overlap. I have already thought of a way of doing this-I
> guess it
> would naturally come to mind of every GRASS user. This would involve
> converting the vectors into a rasters and then query the raster
> grid and
> the rasterized vectors with r.stats. This would be very easy to
> do, but
> my vectors have very small islands, which can, of course, be
> converted
> into raster cells, if I set them my region to a very fine resolution
> for. However, if I went down this route, this would: i)
> massively slow
> down vector to raster conversion ii) massively slow down the r.stats
> querying process. Just to give you an idea of the magnitude of my
> problem I am using several vector layers (hundreds) at global
> level and
> a raster grid at a 2 arc-minutes resolution. I am kind of stuck
> and I am
> not sure if there is any computationally efficient strategy to
> do what I
> want. Any help would be greatly appreciated!
> One possible option I see allowing you to keep your original
> resolution is to use v.to.points (type=boundary and dmax
> sufficiently small) to transform your polygon boundaries to points,
> then v.to.rast to transform that to raster.
> Moritz
