[GRASS-user] result from g.copy when layer exists
Rainer M Krug
Rainer at krugs.de
Wed Jul 17 23:39:37 PDT 2013
Glynn Clements <glynn at gclements.plus.com> writes:
> Rainer M Krug wrote:
>> I am a bit irritated, ut maybe I don't dee the reasoning behind this:'
>> | RASS 7.0.svn (grass):~ > g.copy rast=MASK,tmp
>> | WARNING: <tmp> already exists
>> | [Raster MASK present]
>> | GRASS 7.0.svn (grass):~ >
>> If the layer already exists, shouldn't the command give actually an
>> error and not only a warning?
>> A warning implies for me that the command worked, but maybe something
>> unexpected could have happened (or happened) - but this one clearly did
>> not work, as the layer has not been copied?
> In GRASS, errors are fatal; the program will be terminated as soon as
> the error message has been printed.
Exactly - if e.g. in r.mapcalc an invalid expression is entered,
r.mapcalc issues the error message and quits.
> Each of g.copy's options accept an arbitray number of
> source+destination pairs, and the various options aren't mutually
> exclusive (e.g. a single invocation can copy both raster and vector
> maps).
True.
> If it can't perform a particular copy for any reason, it generates a
> warning then moves on to the next item.
True - but this does not answer my question. But I looked at cp in bash,
and it behaves in the same way.
So I think I have to live with this.
Thanks,
Rainer
Rainer M. Krug
email: RMKrug<at>gmail<dot>com
