[GRASS-user] result from g.copy when layer exists
Rainer M Krug Rainer at krugs.de
Thu Jul 18 04:57:51 PDT 2013
Nikos Alexandris <nik at nikosalexandris.net> writes:
> Rainer MK wrote:
>> >> I am a bit irritated,  ut maybe I don't dee the reasoning behind this:'
>> >> | RASS 7.0.svn (grass):~ > g.copy rast=MASK,tmp
>> >> | WARNING: <tmp> already exists
>> >> | [Raster MASK present]
>> >> | GRASS 7.0.svn (grass):~ >
>> >> If the layer already exists, shouldn't the command give actually an
>> >> error and not only a warning?
>> >> A warning implies for me that the command worked, but maybe something
>> >> unexpected could have happened (or happened) - but this one clearly did
>> >> not work, as the layer has not been copied?
> Glynn Clements:
>> > In GRASS, errors are fatal; the program will be terminated as soon as
>> > the error message has been printed.
> Rainer MK:
>> Exactly - if e.g. in r.mapcalc an invalid expression is entered,
>> r.mapcalc issues the error message and quits.
>> > Each of g.copy's options accept an arbitray number of
>> > source+destination pairs, and the various options aren't mutually
>> > exclusive (e.g. a single invocation can copy both raster and vector
>> > maps).
>> True.
>> > If it can't perform a particular copy for any reason, it generates a
>> > warning then moves on to the next item.
>> True - but this does not answer my question. But I looked at cp in bash,
>> and it behaves in the same way.
>> So I think I have to live with this.
> Just sharing my thoughts about: Imagine copying 1000 maps.  And one is meant
> to fail, say the 1st one of them.  You wouldn't, probably, like the copy
> process to be interrupted just for one map that failed. Right?
Depends: when using in a script, I would like it to fail, as the
following commands might give wrong resuls as they would be based on the
previous map and not the copied one.
Also, in a script this could mean that previous commands did not clean
their temporary files properly - other cause for an interruption of the
script.
When doing it from the command prompt, I would say: just tell me which
ones failed - correct.
SO the best would be a flag which says "error on map exists".
Cheers,
Rainer
> Greets, Nikos
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
