[GRASS-user] polygon overlapping
Agustin Diez Castillo agustin.diez at uv.es
Fri Jul 19 10:10:10 PDT 2013
Maybe concave hull can help?
http://grasswiki.osgeo.org/wiki/Create_concave_hull
Agustin
On 19/07/2013, at 16:06, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> hi, is it possible to create polygons based on points, so that the
> polygons can share boundary (ideal case), but can not overlap - see
> attached image.
> v.hull does not solve the "can't overlap" problem
> one possible solution:
> 1) v.hull
> 2) v.to.rast
> 3) r.patch
> 4) r.to.vect
> But not so nice solution
> Any hint?
> Thanks
> Jachym
> <polygon_creation_problem.jpg>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
