[GRASS-user] result from g.copy when layer exists
Nick Ves
vesnikos at gmail.com
Tue Jul 23 13:39:00 PDT 2013
Since we're talking about grass errors, is there a way to redirect the
warnings/errors ?
e.g. r.mapcalc "..." 2>error.log
On Fri, Jul 19, 2013 at 10:14 AM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Thu, Jul 18, 2013 at 1:57 PM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Nikos Alexandris <nik at nikosalexandris.net> writes:
>>> Rainer MK wrote:
>>>> >> I am a bit irritated, ut maybe I don't dee the reasoning behind this:'
>>>> >> | RASS 7.0.svn (grass):~ > g.copy rast=MASK,tmp
>>>> >> | WARNING: <tmp> already exists
>>>> >> | [Raster MASK present]
>>>> >> | GRASS 7.0.svn (grass):~ >
>>>> >> If the layer already exists, shouldn't the command give actually an
>>>> >> error and not only a warning?
>>>> >> A warning implies for me that the command worked, but maybe something
>>>> >> unexpected could have happened (or happened) - but this one clearly did
>>>> >> not work, as the layer has not been copied?
>>> Glynn Clements:
>>>> > In GRASS, errors are fatal; the program will be terminated as soon as
>>>> > the error message has been printed.
>>> Rainer MK:
>>>> Exactly - if e.g. in r.mapcalc an invalid expression is entered,
>>>> r.mapcalc issues the error message and quits.
>>>> > Each of g.copy's options accept an arbitray number of
>>>> > source+destination pairs, and the various options aren't mutually
>>>> > exclusive (e.g. a single invocation can copy both raster and vector
>>>> > maps).
>>>> True.
>>>> > If it can't perform a particular copy for any reason, it generates a
>>>> > warning then moves on to the next item.
>>>> True - but this does not answer my question. But I looked at cp in bash,
>>>> and it behaves in the same way.
>>>> So I think I have to live with this.
>>> Just sharing my thoughts about: Imagine copying 1000 maps. And one is meant
>>> to fail, say the 1st one of them. You wouldn't, probably, like the copy
>>> process to be interrupted just for one map that failed. Right?
>> Depends: when using in a script, I would like it to fail, as the
>> following commands might give wrong resuls as they would be based on the
>> previous map and not the copied one.
>> Also, in a script this could mean that previous commands did not clean
>> their temporary files properly - other cause for an interruption of the
>> script.
>> When doing it from the command prompt, I would say: just tell me which
>> ones failed - correct.
>> SO the best would be a flag which says "error on map exists".
> The other way around: you can enforce copying (overwrite existing
> maps) with g.copy --o
> Markus M
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
