[GRASS-user] Possible to switch off permissions check of mapsets?
Nikos Alexandris
nik at nikosalexandris.net
Wed Jul 31 12:59:18 PDT 2013
Michel Wortmann:
> > And straight on to another question:
> > Is there a way of switching of the permissions check when opening a
> > mapset? It prevents me from opening mapsets that are mounted on
> > different filesystems as the grass installation. E.g. if I try to open a
> > mapset located on a remote directory (mounted using fuse) in my local
> > Ubuntu grass6.4 version fails with:
> > ERROR: MAPSET PERMANENT - permission denied
> > Any solution to this would be much appreciated.
Tim Michelsen:
> I totally agree with you. Especially for the 1 machine with dual boot
> set-up.
> Unfortunately, core developers are of different opinion:
> [Fwd: Re: GRASS permission issue]
> http://thread.gmane.org/gmane.comp.gis.grass.devel/39132/focus=39146
> Hope if more come in we could convince them...
> Regards.
Tim,
I have never ever had such a "problem" -- it always was in the end a
permission issue on the "operating system world". That is, one has to
properly mount the drive/filesystem he wants to use under its own user-id (at
least in Linux) and there will be no issue.
Best regards, Nikos
