[GRASS-user] Possible to switch off permissions check of mapsets?
Hamish
hamish_b at yahoo.com
Wed Jul 31 19:59:56 PDT 2013
>>> ERROR: MAPSET PERMANENT - permission denied
>>> Any solution to this would be much appreciated.
Glynn:
>> In any of the current SVN versions,
>> setting the environment variable GRASS_SKIP_MAPSET_OWNER_CHECK
>> to any non-empty string will suppress the check.
(that also includes 6.4.3-final by the way)
Tim:
> Yes, but what for the people who wanna rely on the precompiled packages?
> And this could be a switch in the .grassrc or elsewhere.
it still works at run time. you can make it locally permanent on a
single user setup with:
echo "export GRASS_SKIP_MAPSET_OWNER_CHECK=true" >> ~/.grass.bashrc
As with anything else, be sure to extra take care when disabling
safety mechanisms.
Hamish
ps- the build-time compiler flag version is "-DSKIP_MAPSET_OWN_CHK"
