[GRASS-user] [GRASS GIS] #1924: r.watershed - empty stream segment map
Johannes Radinger
johannesradinger at gmail.com
Mon Jun 3 06:30:51 PDT 2013
Hi Markus,
Hi others,
I am coming back to the topic of running r.watershed on a rasterized river
network.
As recommended I buffered now my river raster. This river raster is a
thinned distance raster
with increasing values from the outlet to the branches (calculated via
r.cost) and as
I said it is buffered now with a very large value (2 x max of the thinned
distance raster).
So actually this should work as an input map to r.watershed. And it does
more or
less perfectly: There's just one issue concerning the outlet-stream segment.
Somehow this (in my case small segment, in the south-west corner) is
missing in the stream-map output of r.watershed.
I am working on GRASS6.5. Attached there is a zipped GTIFF with the
"pseudo-elevation" map
(this thinned and buffered distance raster) I am using as input to
r.watershed.
The command I am using is:
r.watershed -f --overwrite elevation=buffer_river_raster
stream=test_segments threshold=3
The threshold has been set to 3 as this is the number of raster cells that
refer to the buffer (3 x resolution)
Can anyone reproduce that the outlet small river segment is missing in the
produced "test_segments"??
What is causing that?
/Johannes
> Reporter: jradinger | Owner: grass-dev@…
> Type: defect | Status: new
> Priority: normal | Milestone:
> Component: Raster | Version: svn-trunk
> Keywords: | Platform: Linux
> Cpu: x86-32 |
> Comment(by mmetz):
> Replying to [comment:2 jradinger]:
> > Two more important things:
> > 1) The elevation input map is accutally already a thinned river raster.
> The raster
> > values represent a pseude elevation which was generated with r.cost
> from the source.
> > Thus the value (elevation) is increasing upstream. r.watershed is just
> used for getting
> > the flowdirection and segmenting the river raster. (if needed I can
> provide the elevation-rcost
> > raster)
> r.watershed expects a surface as input. Using a thinned river raster as
> input should give weird results: all non-NULL cells face at least one NULL
> cell treated as unknown elevation, thus flow direction can not be
> unambiguously determined. You can try to place a buffer around the rivers
> and fill the buffer with pseudo-elevation values larger than the largest
> cost value. For example, create a buffer using 300 meter (3 cells) as
> distance, set a pseudo elevation value for the buffer zone, patch the
> thinned river raster with the pseudo elevation, run r.watershed with
> threshold=3. Works for me.
> > And maybe a warning/error message should be printed when threshold = 0,
> instead of the (for me confusing error)
> Makes sense.
> Markus M
> Ticket URL: <http://trac.osgeo.org/grass/ticket/1924#comment:3>
> GRASS GIS <http://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130603/0492d411/attachment-0001.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130603/0492d411/attachment-0001.zip>
