[GRASS-user] Using PVGIS Raster Files in GRASS
James Allan
James.Allan at brunel.ac.uk
Mon Jun 3 08:21:06 PDT 2013
Hi All,
I am very new to GRASS and I need to use the r.sun function to determine the incident solar radiation on a surface. I have downloaded the PVGIS dataset from http://re.jrc.ec.europa.eu/pvgis/download/solar_radiation_cmsaf_download.html and have tried importing it into the layer manager as a grid ascii file. I was successfully able to import the file but now all I see is a purple square in the map display. Please see attached. I was expecting to see a map of Europe and Africa with the corresponding radiation data.
If you have any experience with solar radiation files or importing these types of files into GRASS I would really appreciate your help.
Best Regards
James Allan
Name: PVGIS Problem.jpg
Type: image/jpeg
Desc: PVGIS Problem.jpg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130603/39ab47ef/attachment-0001.jpg>
