[GRASS-user] v.extract features based on multiple SQL statements in	one go
    Nikos Alexandris
    nik at nikosalexandris.net
    Tue Jun  4 04:49:45 PDT 2013
Hi list!
Can I avoid the "for loop + v.patch" below
	for PATHROW in `cat wrspr_of_interest`; do v.extract --o in=wrs2_descending
type=area where="WRSPR = ${PATHROW}" output=wrs2_of_interest_${PATHROW}; done
	v.patch in=g.mlist vect pat=wrs2*_?????? out=wrs2_tiles_of_interest
and do all the magic in one step instead? As in feeding multiple SQL
statements/lines in db.execute?  v.extract does not seem to support this
(maybe too complicated).
Is the only alternative to construct a single-long SQL statement? Using, e.g.
# what is requested?
cat /geo/geodata/mangroves/geolocations/sources/ascii/wrspr_of_interest2
SELECT * FROM wrs2_descending WHERE WRSPR = 160043 or WRSPR = 161043 or WRSPR
= 193056
# select it
cat /geo/geodata/mangroves/geolocations/sources/ascii/wrspr_of_interest2 |
db.select input=-
cat|AREA|PERIMETER|PR_|PR_ID|RINGS_OK|RINGS_NOK|WRSPR|PR|PATH|ROW|MODE|
DAYCLASS|SEQUENCE
12071|2.82726|6.76119|2523|2523|1|0|160043|160043|160|43|D|7|22611
24719|2.82726|6.76119|2523|2523|1|0|161043|161043|161|43|D|14|47907
24980|2.59335|6.45272|3032|3032|1|0|193056|193056|193|56|D|14|48416
Even so, I can't feed this to "v.extract" directly.
Sidenote:  I am trying to trace a, maybe similar, action of mine some years
ago, where Hamish pointed how inefficient my script-ing was, opening/executing
SQL/closing multiple times a file.  Can't locate it though.
Thanks, Nikos
