[GRASS-user] [GRASS-dev] how to make non-merged buffers?
Michael Barton
Michael.Barton at asu.edu
Tue Jun 4 10:54:47 PDT 2013
So this is odd.
I have 166 points, with a few cases where 2 points are in the same location
I created a set of circular buffers around the points with
v.buffer -t input=neolithic_sites type=point output=sites5km distance=5000
This indeed created a set of overlapping (non-merged), circular buffers.
BUT, it creates 212 areas and 100 islands according to the command output and metadata report (v.report).
There are only 166 attribute table entries.
So what are the extra areas and the islands?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jun 3, 2013, at 12:20 AM, Markus Metz <markus.metz.giswork at gmail.com> wrote:
> On Mon, Jun 3, 2013 at 1:08 AM, Hamish <hamish_b at yahoo.com> wrote:
>> Michael wrote:
>>>> Is there a way to create buffers around features that
>>>> overlap when the features are near to each other instead of
>>>> merging?
>> Markus M wrote:
>>> In GRASS 7, with v.buffer -t
>> for the sake of completeness, in 6.3.0 you could do this with
>> the debug= option, but that did not continue into the replacement
>> 6.4 module. There you'd have to run it in a loop then combine with
>> v.patch.
> To be precise, the 6.3 debug= option as well as the v.patch solution
> produce really overlapping areas with broken topology. The 7.0 -t flag
> preserves the categories of the input features and cleans topology.
> Areas in the output can have more categories, one for each input
> feature in case of overlapping buffers. Thus you have clean topology
> and you can extract single buffers. See the example in the 7.0 manual.
> Markus M
