[GRASS-user] grass vector model, cats and layers concept
Nikos Alexandris
nik at nikosalexandris.net
Thu Jun 6 05:52:17 PDT 2013
Nikos A wrote:
> >> > Still, I find it counter-intuitive that it's required to create
a new
> >> > vector map to achieve that.
> >> > v.category in=wrs2_tiles_of_interest_testing at PERMANENT layer=2
> >> > option=add
> >> > ERROR: Output vector wasn't entered
Markus Metz wrote:
> >> Because you need to modify vector geometries in order to add a
new
> >> layer. Categories and layers are first and foremost stored
together
> >> with the geometries. Whenever geometries are modified, the result
will
> >> be a new vector map (with the exception of v.edit and the
digitizers).
Nikos A:
> > Just for (even more) completeness and understanding: adding a new
layer
> > does not really change the geometries per-se (that is the
topology, the
> > shape).
Markus Metz:
> No, it does change the geometry directly.
O-K. This is where I am confused.
> > It's the inner design of the vector data model, i.e. the fact that
> > categories and layers are bound together. Is it wrong to describe
it as an
> > internal "indexing" issue or similar?
> Yes, it is wrong. Categories and layers are first and foremost
stored
> together with the geometries.
I'll try to consult the programmer's manual or else about the vector
data model. I need to clarify this to myself :-).
> Therefore adding a new layer will modify the geometries directly.
IOW,
> categories and layers are part of the (GRASS) vector geometry
objects.
Rigth, I need to (re-)define to myself the "geometries" term.
> Also, layers and categories have nothing to do with topology.
A-ha...
> A new layer really is only added by modifying the geometries, only
after
> that you might want to attach a table to that new layer.
Will check the manuals...
> I guess you confuse layer with database connection. The existence of
a
> layer is a condition for an optional database connection. A database
> connection itself does not mean the layer of this connection
actually
> exists.
Danke Markus.
I am not really confused over the layer/db-connection stuff. Rather,
it is the topology - geometry - categories and layers stuff that I am
confused about.
Nikos
