[GRASS-user] grass vector model, cats and layers concept
Nikos Alexandris
nik at nikosalexandris.net
Thu Jun 6 14:02:46 PDT 2013
Nikos A wrote:
> >>>>> Still, I find it counter-intuitive that it's required to
create a new
> >>>>> vector map to achieve that.
> >>>>> v.category in=wrs2_tiles_of_interest_testing at PERMANENT layer=2
> >>>>> option=add
> >>>>> ERROR: Output vector wasn't entered
Markus Metz wrote:
> >>>> Because you need to modify vector geometries in order to add a
new
> >>>> layer. Categories and layers are first and foremost stored
together
> >>>> with the geometries. Whenever geometries are modified, the
result will
> >>>> be a new vector map (with the exception of v.edit and the
digitizers).
Nikos A:
> >>> Just for (even more) completeness and understanding: adding a
new layer
> >>> does not really change the geometries per-se (that is the
topology, the
> >>> shape).
Markus Metz:
> >> No, it does change the geometry directly.
> > O-K. This is where I am confused.
> >>> It's the inner design of the vector data model, i.e. the fact
that
> >>> categories and layers are bound together. Is it wrong to
describe it as
> >>> an internal "indexing" issue or similar?
> >> Yes, it is wrong. Categories and layers are first and foremost
stored
> >> together with the geometries.
> > I'll try to consult the programmer's manual or else about the
vector
> > data model. I need to clarify this to myself :-).
> >> Therefore adding a new layer will modify the geometries directly.
IOW,
> >> categories and layers are part of the (GRASS) vector geometry
objects.
> > Rigth, I need to (re-)define to myself the "geometries" term.
> >> Also, layers and categories have nothing to do with topology.
> > A-ha...
> >> A new layer really is only added by modifying the geometries,
only
> >> after that you might want to attach a table to that new layer.
> > Will check the manuals...
> >> I guess you confuse layer with database connection. The existence
of a
> >> layer is a condition for an optional database connection. A
database
> >> connection itself does not mean the layer of this connection
actually
> >> exists.
> > I am not really confused over the layer/db-connection stuff.
Rather,
> > it is the topology - geometry - categories and layers stuff that I
am
> > confused about.
Moritz Lennert wrote:
> I think the confusion comes from the fact that what Nikos calls
> "geometry" is the part "drawn" on the screen, i.e. the geometrical
> features visible to the user when displaying a map. Markus speaks
about
> "geometry" in the programming sense, i.e. the programmed structure
that
> represents the geometrical features, but which contains more than
just
> the "visible" geometric parts (i.e. the coordinates), e.g. it also
> contains the information about the type of geometry and the possible
> layers (aka fields) and category values. See:
http://grass.osgeo.org/programming7/vlibFormat.html#vlibCoorFileFormat
@Moritz: eXactly that. Milles mercis, Nikos
