[GRASS-user] Merge parallel roads
Hendrik Hoeth
hoeth at linta.de
Sun Jun 9 01:11:20 PDT 2013
I need to merge parallel roads, like highway lanes, into one. I've
looked around a bit and found solutions for ArcGIS ("Collapse Dual Lines
To Centerline") and for OSM XML files (Skeletron), but nothing that
works straight in GRASS. What's the best way of doing this in GRASS?
Cheers,
Hendrik
If your dreams don't scare you, then you are not dreaming big enough.
