[GRASS-user] Installing GRASS on Ubuntu: compilation error
RichardC
richtcooper at hotmail.com
Thu Jun 13 08:53:30 PDT 2013
Configure proceeds without error after removing
--with-gdal=/home/rcooper/grass7/bin/gdal-config
However, I receive the following error re running configure for
gdal-grass-1.4.3 $ ./configure \
> --prefix=/home/rcooper/grass7 \
> --with-gdal=/home/rcooper/grass7/bin/gdal-config \
> --with-grass=/home/rcooper/grass7/grass7_trunk/ \
> --with-autoload="/usr/local/lib/gdalplugins/" \
> --with-ld-shared="g++ -shared"
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for ranlib... ranlib
using user supplied .so link command ... g++ -shared
user supplied gdal-config (/home/rcooper/grass7/bin/gdal-config)
using /usr/local/lib/gdalplugins/ as GDAL shared library autoload directory
checking for G_asprintf in -lgrass_gis... no
configure: error: --with-grass=/home/rcooper/grass7/grass7_trunk/ requested,
but libraries not found! Perhaps you need to set LD_LIBRARY_PATH to include
/home/rcooper/grass7/grass7_trunk//lib?
I believe I can set the PATH by modifying .profile in Ubuntu.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Installing-GRASS-on-Ubuntu-compilation-error-tp5059904p5059973.html
Sent from the Grass - Users mailing list archive at Nabble.com.
