[GRASS-user] R: Re: R: Re:  problem add-ons and python (windows7)
    Mattia Riccadonna
    Mattia_r at libero.it
    Fri Jun 14 01:08:20 PDT 2013
OK, finally I solved the problem. I just set in the right way all the PATH you
have mentioned, and changed the .bat file in the right way. Thanks Hamish!
>----Messaggio originale----
>Da: hamish_b a yahoo.com
>Data: 11/06/2013 12.39
>A: <grass-user a lists.osgeo.org>, "Mattia Riccadonna"<Mattia_r a libero.it>
>Ogg: Re: R: Re: [GRASS-user] problem add-ons and python (windows7)
>Hamish:
>>> And/or the set PATHENV in \etc\Init.bat is not working properly.
>>> (it knows about .py but doesn't know to associateit with GRASS's
>>> python.exe)
>Mattia wrote:
>> Honestly I have not found the PATHENV in \etc\Init.bat. Is it a problem?
>it should be there on line 69. I'm not sure if it means much without
>assoc and ftype (see below).
>> I tryed to know which one is the path that corresponds to python.exe
>> but I wasn't able. The command try to open .py file always with pythom.exe
>> from \extrabin.
>On a copy of GRASS 6.4.3svn nightly build from today or yesterday,
>running "echo $GRASS_PYTHON" from the Msys terminal, or
>"echo %GRASS_PYTHON%" from the C:\> dosbox window (both in the GRASS
>section of the Start Menu) should show it.
>wrt finding Matplotlib, the %PYTHONPATH% (or $PYTHONPATH) variable may be
>interesting to look at as well. (apparently we don't ship it [yet])
>you might also try this tip from the python docs, add this to C:\Program
>Files\GRASS...\etc\env.bat:
>  (http://docs.python.org/2/using/windows.html#executing-scripts)
>assoc .py=Python.File
>ftype Python.File="%GRASS_PYTHON%" "%1" %*
>outside of the GRASS environment would probably be an error since
>PYTHONPATH wasn't set system-wide.
>you might also try changing the GRASS_PYTHON and PYTHONPATH to your
>system installed Python.exe and support files, and so matplotlib too.
>(change them together, keep them in sync)
>>> Secondly, there is a .bat wrapper called %ADDONS%/scripts/r.basin.py.bat
>>> which should be in %ADDONS%, and be named r.basin.bat.
>> I wasn't able to find where to set %ADDONS% too. I saw only %
>> GRASS_ADDON_PATH%. So confused :)
>sorry, I was in a rush and abbreviated it. %GRASS_ADDON_PATH% is correct.
>> In addition, I used g.extension to get add-ons. And with that command
>> there aren't make files in any folder. Have I to re-download them
>> manually? In case, where have I to put make files?
>that part of my comment was mostly meant for the developers. Since most
>Windows users don't have the full compiler and osgeo4w build environment
>set up on Windows we (ie Martin) provides pre-built versions. For python
>and shell scripts it isn't a big deal since there's noting to build, but
>copying everything into the right spot and getting the extensions working
>correctly can be a pain, as you've experienced.
>You might also try to replicate the setup of e.g. d.rast3d.py and .bat
>in C:\Program Files\GRASS...\etc\gui\scripts\, I tried that but no luck.
>I know we're very close on python scripts + GRASS 6.4 + Windows, it's a
>bit frustrating missing that last piece of the puzzle... after all the
>g.extension.py script you used to download starts runs ok...
>Hamish
