[GRASS-user] R: Re: r.hazard.flood white map flood output
M. Riccadonna
Mattia_r at libero.it
Fri Jun 14 01:57:12 PDT 2013
Sure,
g.region -p
projection: 1 (UTM)
zone: 32
datum: wgs84
ellipsoid: wgs84
north: 5110010
south: 5103990
west: 621990
east: 634010
nsres: 1.204
ewres: 1.202
rows: 5000
cols: 10000
cells: 50000000
r.info bacino_dtm
| Type of Map: raster Number of Categories: 255 |
| Data Type: FCELL |
| Rows: 5000 |
| Columns: 10000 |
| Total Cells: 50000000 |
| Projection: UTM (zone 32) |
| N: 5110010 S: 5103990 Res: 1.204 |
| E: 634010 W: 621990 Res: 1.202 |
| Range of data: min = 1026.483 max = 3465.358 |
| Data Description: |
| generated by r.mapcalc |
| Comments: |
r.hazard.flood.PY --overwrite map=zzzzzzz flood=zzzzz_flood mti=zzzzzzzzzz_MTICellsize : 1.203SEZIONE 1a (di 4): Inizializando Memoria.SECTION 1b (of 4): Determining Offmap Flow.SEZIONE 2: A * Search.SECTION 3: Accumulating Surface Flow with MFD.SEZIONE 4: Chiudendo Mappe.WARNING: Writing out only positive flow accumulation values.WARNING: Cells with a likely underestimate for flow accumulation can no longer be identified.Flow accumulation done.Mappa raster delle pendenze <r_slope> completataSlope map done.Exponent : 0.0174197601602MTI threshold : 2.47170118814Calculating mti raster map..Cleaning up..Removing raster <r_accumulation>Removing raster <r_slope>Calculating flood raster map..Running r.clump..Pass 1...Pass 2...r.clump completo. 38808 clumps.Deleting areas of less than 690985 cells..Reading...Writing...Done!Cleaning up..Removing raster <r_clump>Removing raster <r_flood_th>Removing raster <r_flood>Done!
thanks..
m
Un allegato HTML � stato rimosso...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130614/0d4a537e/attachment-0001.html>
