[GRASS-user] Directed vector networks (e.g. river networks)
Pietro Zambelli peter.zamb at gmail.com
Fri Jun 14 03:49:42 PDT 2013
Hi Johannes,
On Friday 14 Jun 2013 11:03:04 Johannes Radinger wrote:
> Hi,
> as I am not very familiar with GRASS' vector capabilities maybe someone of
> you has some ideas. Is there the concept of directed vector networks e.g
> describing river networks with flow direction implemented in GRASS?
Each line in GRASS is just an array of points, therefore for each line you
have a direction from the first point to the last.
If the direction is not correct you can change with reverse.
A possible way to check the right direction using pygrass is (note, not
tested, and pygrass is only available in grass7):
from grass.pygrass.vector import VectorTopo
from grass.pygrass.raster import RasterRow
from grass.pygrass.gis.region import Region
def check_line(line, elevation, region):
    first = elevation.get_value(line[0], region)
    last = elevation.get_value(line[-1], region)
    if first < last:
        line.reverse()
    return line
def check_direction(vectorname, elevname, outputname):
    """Check if the direction of a river network is correct"""
    river = VectorTopo(vectorname)
    river.open()
    newriver = VectorTopo(outputname)
    newriver.open('w', tab_cols=river.table.columns.items())
    elevation = RasterRow(elevname)
    elevation.open()
    region = Region()
    for line in river:
        newline = check_line(line, elevation, region)
        newriver.write(newline, attrs=line.attrs.values())
    newriver.table.conn.commit()
    river.close()
    newriver.close()
    elevation.close()
check_direction('river', 'elevation', 'river_checked')
Of course you can implement the same in C.
For the other questions I'm not sure which is the best way to follow.
All the best.
Pietro
