[GRASS-user] r.hazard.flood white map flood output
Margherita Di Leo
diregola at gmail.com
Fri Jun 14 02:51:59 PDT 2013
Thanks Mattia, what I think it happens is that the areas individuated
(those which exceed the MTI threshold : 2.47170118814) are too small and
are being deleted by r.area afterwards. I'm most interested in pushing this
testing beyond, as the module is the implementation of an experimental
procedure developed by us, so if you are available to do further tests I'd
follow up this off list. Let me know if you are available.
Thanks m
On Fri, Jun 14, 2013 at 11:26 AM, M. Riccadonna <Mattia_r at libero.it> wrote:
> sure, ok!
> | Range of data: min = -3.09747448418923 max = 11.1769558173435
Best regards,
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not
in any circumstance be regarded as stating an official position of the
European Commission.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130614/04076f38/attachment.html>
