[GRASS-user] r.neighbors velocity
Markus Metz
markus.metz.giswork at gmail.com
Sat Jun 29 03:19:28 PDT 2013
Some more results with Sören's test program on a Intel(R) Core(TM) i5
CPU M450 @ 2.40GHz (2 real cores, 4 fake cores) with gcc 4.7.2 and
clang 3.3
gcc -O3
v is 2.09131e+13
real 2m0.393s
user 1m57.610s
sys 0m0.003s
gcc -Ofast
v is 2.09131e+13
real 0m7.218s
user 0m7.018s
sys 0m0.017s
gcc -Ofast -floop-parallelize-all is as fast as gcc -Ofast
clang -Ofast
v is 2.09131e+13
real 0m18.701s
user 0m18.285s
sys 0m0.000s
Markus M
On Sat, Jun 29, 2013 at 8:35 AM, Hamish <hamish_b at yahoo.com> wrote:
> Hi,
> here are the same results for Soeren's test program, with the Open64
> compiler from AMD:
> - Same AMD X6 CPU as below.
> - Open64 compiler 4.5.2.1 from AMD (GPLv2, LGPL)
> I just downloaded the pre-built RHEL5 binary tarball and they worked
> on Debian/squeeze, I just made an alias to the executable in the un-
> tarred bin/ dir to get it to work.
> see also http://wiki.open64.net/index.php/Installation_on_Ubuntu
> Source is available of course, but according to the Debian ITP ticket
> it's a bit of a pain to build there.
> straight opencc:
> real 0m59.015s | 0m58.972s | 0m58.963s
> user 0m58.760s | 0m58.812s | 0m58.624s
> sys 0m0.248s | 0m0.136s | 0m0.300s
> opencc -O3:
> real 0m35.203s | 0m35.173s | 0m35.204s
> user 0m35.206s | 0m35.174s | 0m35.206s
> sys 0m0.000s | 0m0.000s | 0m0.000s
> opencc -Ofast (with or without -march=auto for native bytecode)
> real 0m13.389s | 0m13.402s | 0m13.435s
> user 0m13.389s | 0m13.405s | 0m13.437s
> opencc -Ofast -march=auto -apo on a 6-(real)-core CPU
> v is 2.09131e+13
> real 0m2.552s | 0m2.595s | 0m2.591s
> user 0m14.857s | 0m14.725s | 0m14.725s
> sys 0m0.008s | 0m0.024s | 0m0.016s
> '-apo' is autoparallelization, poorly documented, but it works!
> it adds OpenMP pragmas where it thinks it can && where it will
> cause a gain; I'm glad to see it's not just for the fotran
> compiler anymore.
> So the Open64 compiler is not quite as fast as Intel's one for this
> test case, but it's pretty close versus the more versatile gcc in the
> far distance. Executable file size for all of the above was less than
> 12kb, since it can link to local OS shared libs.
> I haven't tried it with llvm/clang.
> Now I wonder which flags to use to recreate -Ofast in gcc to make it
> a fairer comparison..
> Hamish
>> I also ran it on an AMD Phenom II X6 1090T (icc -xHost --> -xSSSE3 ?)
>> All times "real"; all output was "v is 2.09131e+13".
>> gcc 4.4.5 with standard-opts: 7kb binary
>> == near parity single-threaded performance with the new i7 chip from
>> the 2 year old AMD Phenom and older copy of gcc! (stock debian/squeeze)
>> 1m16.175s | 1m15.634s | 1m16.029s
>> icc 12.1 with standard-opts:
>> 0m32.975s | 0m33.079s | 0m33.249s
>> icc with "-fast" opt: (700kb binary)
>> 0m9.577s | 0m9.572s | 0m9.583s
>> icc with -parallel auto-MP: (31kb binary)
>> == again near parity with the new i7 chip! even with the Intel-biased
>> compiler. "user" cpu-time was actually less. the advantage of 6 real
>> cores vs 4 real+4virtual ones.*
>> 0m6.406s | 0m6.404s | 0m6.404s
>> 0m37.106s | 0m37.170s | 0m37.106s
>> 0m0.044s | 0m0.040s | 0m0.028s
>> icc with -fast and -parallel: (2mb binary)
>> 0m2.002s | 0m2.002s | 0m2.002s
>> 0m10.765s | 0m10.769s | 0m10.769s
>> 0m0.016s | 0m0.012s | 0m0.008s
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
