[GRASS-user] Fwd: How to obtain selected adjacent pixel values?
Markus Metz
markus.metz.giswork at gmail.com
Sun Jun 30 12:10:11 PDT 2013
On Sun, Jun 30, 2013 at 3:31 PM, Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> (cc-ing @MarkusMetz)
> Yasser Said Lopez de Olmos Reyes wrote:
>> > How could I obtain the differences between central pixel values and
>> > cardinal directions pixel values related with a central pixel?
>> > Or in a different manner, how to do this in grass gis?
>> > RASTER_OUT= round(abs((RASTER_IN - RASTER_IN_PUSHED_ONE_ROW_UP) +
>> > (RASTER_IN - RASTER_IN_PUSHED_ONE_ROW_DOWN) + (RASTER_IN -
>> > RASTER_IN_PUSHED_ONE_COLUMN_LEFT) + (RASTER_IN -
>> > RASTER_IN_PUSHED_ONE_COLUMN_RIGHT))
> Nikos Alexandris wrote:
>> This boils down to calculating
>> (RASTER_IN - RASTER_IN_PUSHED_ONE_COLUMN_LEFT) +
>> (RASTER_IN - RASTER_IN_PUSHED_ONE_COLUMN_RIGHT)
>> Please check the manual of r.mapcalc. There is
>> THE NEIGHBORHOOD MODIFIER
>> which I think can be used to obtain what is asked.
>> So, for each of the off-current pixel, the modifiers would be like
>> RASTER_IN_PUSHED_ONE_ROW_UP: map[-1,0]
>> RASTER_IN_PUSHED_ONE_ROW_DOWN: map[1,0]
>> RASTER_IN_PUSHED_ONE_COLUMN_LEFT: map[0,-1]
>> RASTER_IN_PUSHED_ONE_COLUMN_RIGHT: map[0,1]
>> I am not exactly sure about the implementation though.
r.mapcalc "RASTER_OUT=round(abs((RASTER_IN - RASTER_IN[0,-1]) + \
(RASTER_IN -
RASTER_IN[0,1]) + \
(RASTER_IN -
RASTER_IN[-1,0]) + \
(RASTER_IN -
RASTER_IN[1,0])))"
Note that this is the same like round(abs(4 * RASTER_IN -
(RASTER_IN[0,-1] + RASTER_IN[0,1] + RASTER_IN[-1,0] +
RASTER_IN[1,0])))
If you are interested in the sum of the absolute differences, you will
need to use abs() for each difference.
> @Yasser, if you implement this and think it is something that can be justified
> as generically useful, why not ask @MarkusMetz if it is easy to include in
> "r.neighbors" as yet another method?
# prepare a weights file with the contents
0 1 0
1 0 1
0 1 0
r.neighbors in=raster_in out=raster_cardinalsum weight=weights method=sum
r.mapcalc "RASTER_OUT = round(abs(4 * RASTER_IN - raster_cardinalsum))"
HTH,
Markus M
