[GRASS-user] importing raster from a linear projection into current location
Markus Metz markus.metz.giswork at gmail.com
Fri Mar 1 14:16:54 PST 2013
On Fri, Mar 1, 2013 at 11:06 PM, Sebastian P. Luque <spluque at gmail.com> wrote:
> On Fri, 1 Mar 2013 22:42:56 +0100,
> Markus Neteler <neteler at osgeo.org> wrote:
>> On Fri, Mar 1, 2013 at 9:53 PM, Seb <spluque at gmail.com> wrote:
>>> Hi,
>>> I am trying to import a series of rasters (HDF) in a linear
>>> projection, i.e. without any projection information, where x and y
>>> are simple indexes; gdalinfo shows:
>> Could you say a bit more about the HDF files? The xy output is
>> probably right but GCPs may be in the file itself (so gdalwarp is
>> needed or the like).
> This file was produced with WIM/WAM (wimsoft.com), and the full output
> of gdalinfo is:
> $ gdalinfo chl_48_200.hdf
> Driver: HDF4Image/HDF4 Dataset
> Files: chl_48_200.hdf
> Size is 1572, 1114
> Coordinate System is `'
> Metadata:
>   Base=10
>   Intercept=-2
>   Map Projection=WIM Linear
>   Scaling=Logarithmic
>   Slope=0.015
>   WIM Color Range=0, 255
>   WIM Color Stretch=48, 200
>   WIM Linear Coeffs=45, 0.012723, -40, -0.008977
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0, 1114.0)
> Upper Right ( 1572.0,    0.0)
> Lower Right ( 1572.0, 1114.0)
> Center      (  786.0,  557.0)
> Band 1 Block=1572x636 Type=Byte, ColorInterp=Gray
> The relevant information is in the "WIM Linear Coeffs" line, where 45,
> -40 are the coordinates of the upper right corner of the map, and
> 0.012723, -0.008977 are the lon, lat resolution.
It seems that you need to override the projection check with r.in.gdal
-o. After that, you need to fix the raster metadata with r.region.
The lon, lat resolutions look really weird, BTW.
Markus M
> Thanks,
> Seb
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
