[GRASS-user] preserving original resolution with r.in.gdal
Markus Neteler neteler at osgeo.org
Thu Mar 7 12:19:06 PST 2013
On Thu, Mar 7, 2013 at 6:08 PM, Jitendra Kumar <jitendra.ncsu at gmail.com> wrote:
> Hello GRASS-Users:
> While importing a raster map using "r.in.gdal" it uses the resolution of the
> current region for the resulting raster map.
No, this is not the case. It always imports the full map at original resolution.
Likely you have the computation region settings different so that it *appears*
to be different.
Simply:
r.in.gdal mymap.tif output=mymap
g.region rast=mymap -p
and you'll see that it matches. See also
http://grasswiki.osgeo.org/wiki/Computational_region
Cheers
Markus
