[GRASS-user] query raster cell and its neighbors by point
Nikos Alexandris
nik at nikosalexandris.net
Thu Mar 14 12:37:48 PDT 2013
Shaun Langley wrote:
> > I need to easily query a raster and return both the value of the cell and
> > the aggregate value of the 8-cell neighborhood, given a set of point
> > coordinates. I know I can easily do this with r.mapcalc, but that
> > involves running the computation for the entire map even though I'm only
> > interested in a very very small portion. Is there an easier way to do
> > this or am I stuck with the long solution?
Nikos Alexandris wrote:
> What kind of an aggregation exactly? Maybe not straight-through, but
> I think you will be "forced" to use G7:
> http://grass.osgeo.org/grass70/manuals/r.neighbors.html
> in a way like
> r.neighbors \
> input=QueriedRaster \
> selection=CellsOfInterest \
> output=AggregatedRaster \
> method=SomeMethod[,MoreMethods,EvenMoreMethods] \
> size=3 \
> title="Aggregated raster map"
> However, you say you need the "queried" cell-value as well. Maybe combine
> with
> http://grass.osgeo.org/grass70/manuals/r.what
Maybe combine all this with a MASK? i.e., create buffer(s) around your
coordinates of interest, use r.what and r.neighbors then?
(@MMetz -- maybe of your interest?)
And, at this point comes the idea: why not let r.neighbors, when a
"selection=RasterMap" is defined, return in an extra raster map the one-central
queried cell?
Best, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130314/ab62ed76/attachment.pgp>
