[GRASS-user] Migrate to Grass 7 question; vector topology?
    Nikos Alexandris
    nik at nikosalexandris.net
    Fri Mar 15 08:02:01 PDT 2013
On Friday 15 of March 2013 09:31:06 Stephen Sefick wrote:
> All,
> I am thinking of moving to grass7.  I know that the vector back end has
> changed and there is a requirement to rebuild vector topology.
Better & Faster (thanks to all and especially to Markus Metz) :-)
> Once this is done can grass6 still read the vectors with little error?
As far as I can tell, you only need to re-build the topology (if you switch
from G6 to G7 and vice versa).
> I would like to keep grass 6 around to make sure that, if I need to, I can
> use the "old stand by" if I can not figure out how to do it in grass 7.
Me too -- still have G6 aside for working although I do most of the stuff in
G7.
Greets, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130315/0d249f7e/attachment.pgp>
