[GRASS-user] Land-use mapping troubles
Sitansu pattnaik sitansu at gmail.com
Tue Mar 19 03:12:00 PDT 2013
At first glance, it looks like there is a problem with data import. If you
are able to see the imported bands clearly within GRASS, then there could
be problems with the signature collection process. Your current output
looks like the row numbers have been classified instead of the data values
stored in each pixel.
If you can share more information about the data source including format
and the steps you have taken for classification ( groups and subgroup
definiton ), someone can troubleshoot your problem.
Sitansu @ kCube
On Tue, Mar 19, 2013 at 3:22 PM, Devica Ranade <devicaranade at gmail.com>wrote:
> I have been trying to do some land use mapping using GRASS.
> While doing a supervised classification for my LANDSAT image, I got a very
> weird map shown below. (screenshot also attached with this email.)
> Can I please know if this problem is common and if yes, what is the best
> way of dealing with it?
> Thanks a lot,
> Devica..
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130319/751d1a42/attachment.html>
