[GRASS-user] Issue with SVN GRASS build on Windows
    Michael Treglia
    mtreglia at gmail.com
    Wed Mar 20 13:04:38 PDT 2013
Hi all,
Due to an earlier issue with i.landsat.toar, I upgraded to the most recent
version of GRASS available (found here):
http://wingrass.fsv.cvut.cz/grass64/. I was previously using the latest
Stable build (here: http://grass.osgeo.org/grass64/binary/mswindows/native/).
I am running Windows 7, 64 bit.
 When I try to run certain functions, I get errors related to DLLs. For
example, a Windows error pops up when I try to import or export a raster
(r.in.gdal and r.out.gdal through the GUI). The import window will appear
once I click OK to the error, and if I go to use the Import function again,
I do not get the error again during that session.
However, the export function is not working at all. I get a couple of
errors that pop up in Windows:
1) The procedure entry point H5Eauto_is_V2 could not be loacted in the
dynamic lik library hdf5dll.dll
2) The procedure entry point GTIFFreeMemory could not be located in the
dynamic link library gdal19.dll
In case this helps, I've pasted what appears in the Command Console when I
simply try to open GRASS and use the GUI to navigate to Export Common
Raster Formats at the end of the e-mail
Errors also appear in the black-background Command Window along the lines
of this:ERROR 1: Can't load requested DLL:
C:\Python27\Lns\gdal_HDF5Image.dll
127: The specified procedure could not be found.
I tried to install an SVN build of GRASS 7 earlier in the week, and had
similar error messages come up.
Should I just try to use the Stable version of GRASS for now? Or am I
probably doing something incorrectly on the install?
I'm still new to GRASS, and I realize I might be better to run it on a
Linux boot (or at least in a Virtual Machine?), but I won't have time to
learn more about that right now.
Thank you again for any help!
Best regards,
Mike
Text from the Command Console:
  File "C:\Program Files (x86)\GRASS GIS
6.4.3svn\etc\wxpython\lmgr\frame.py", line 557, in OnMenuCmd
GUI(parent = self).ParseCommand(cmd)
6.4.3svn\etc\wxpython\gui_core\forms.py", line 1867, in
ParseCommand
blackList = _blackList)
6.4.3svn\etc\python\grass\script\task.py", line 470, in
parse_interface
tree = etree.fromstring(get_interface_description(name))
6.4.3svn\Python27\lib\xml\etree\ElementTree.py", line 1283,
in XML
return parser.close()
6.4.3svn\Python27\lib\xml\etree\ElementTree.py", line 1636,
in close
self._raiseerror(v)
6.4.3svn\Python27\lib\xml\etree\ElementTree.py", line 1488,
in _raiseerror
raise err
xml.etree.ElementTree
ParseError
unclosed token: line 243, column 1
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130320/d1bd70c1/attachment.html>
