[GRASS-user] [GRASS-dev] What is the meaning of output from	i.cluster
    Nikos Alexandris
    nik at nikosalexandris.net
    Mon Mar 25 17:34:02 PDT 2013
Hello Michael,
Michael Barton wrote:
> i.cluster produces a text output file that looks like this (for the landsat
> 2000 images from the nc_spm_08 demo data set).
> #produced by i.cluster
> #Class 1
> 247
> 69.1174 50.3603 41.3482 18.9514 17.4534 117.049 14.2105
> 10.5837
> 12.6608 22.8737
> 17.1663 29.6708 45.1628
> 7.36345 9.28993 16.6389 47.4367
> 9.14573 9.22619 16.9756 47.1115 70.631
> 7.75037 6.67348 10.1294 13.043 14.9941 17.5505
> 7.63372 6.74497 12.0565 27.4981 43.3025 12.0629 30.7522
> #Class 2
> 2059
> 70.0257 53.2035 46.205 61.085 61.5935 121.271 35.6688
> 9.28262
> 7.5725 9.99696
> 11.3514 11.8868 22.0678
> -6.02017 -0.713125 -9.81723 54.7357
> -1.33501 2.43359 2.91134 15.8135 40.1529
> 4.98865 4.49973 6.3419 -2.73927 -1.77851 11.3745
> 5.31077 6.34246 10.6505 -4.60692 19.1398 3.18893 19.0243
> [more for the other classes]
> So what does this mean? There is no clear explanation of this in the manual,
> and there are no variable names in the output.
> I am guessing that
> line 1 is possibly the number of pixels in the class
I think you are right.
> line 2 is the cluster mean within each original raster input file (landsat
> maps bands in this case)
Yes.
*Note,* however, as previously well-explained by Moritz Lennert
(http://lists.osgeo.org/pipermail/grass-user/2012-October/066046.html):
i.cluster does not cluster all pixels, but only a sample (see parameter
'sample'). The result of that clustering is not that all pixels are assigned
to a given cluster, but only that you have signatures that are
"representative" of a given cluster. If you run i.cluster on the same data
asking for the same number of classes, but with different sample sizes, you
will probably get slightly different signatures for each cluster at each run.
> The remaining lines are some kind of matrix. If a correlation matrix, I
> don't understand why the diagonal is not 1--or at least the biggest number
> for the relevant input maps.
> Any explanation?
It is a variance(=the diagonal)-covariance matrix(=the off diagonal elements)
as described in the manual and mentioned else-where in past threads in the
list.
As previously noted by Hamish Bowman, let's have a look at
(http://lists.osgeo.org/pipermail/grass-user/2008-June/045108.html):
I_fopen_signature_file_new() found in lib/imagery/sigfile.c
but I can't find/understand if it helps.
What about looking at
a) /geo/osgeo/src/grass_trunk/lib/python/ctypes/OBJ.x86_64-unknown-linux-
gnu/imagery.py
or
b) /geo/osgeo/src/grass_trunk/lib/python/ctypes/OBJ.x86_64-unknown-linux-
gnu/cluster.py:
--%<--- a) lines 756-781 / b) lines 579-600 --%<---
# /geo/osgeo/src/grass_trunk/dist.x86_64-unknown-linux-
gnu/include/grass/imagery.h: 51
class struct_One_Sig(Structure):
    pass
struct_One_Sig.__slots__ = [
    'desc',
    'npoints',
    'mean',
    'var',
    'status',
    'r',
    'g',
    'b',
    'have_color',
struct_One_Sig._fields_ = [
    ('desc', c_char * 100),
    ('npoints', c_int),
    ('mean', POINTER(c_double)),
    ('var', POINTER(POINTER(c_double))),
    ('status', c_int),
    ('r', c_float),
    ('g', c_float),
    ('b', c_float),
    ('have_color', c_int),
And then, of course, at
struct One_Sig
    char desc[100];
    int npoints;
    double *mean;		/* one mean for each band */
    double **var;		/* covariance band-band   */
    int status;		/* may be used to 'delete' a signature */
    float r, g, b;		/* color */
    int have_color;
Best, Nikos
Desc: This is a digitally signed message part.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130326/76159824/attachment.pgp>
