[GRASS-user] FW: r.out.xyz: Output error
Stephen Brearley mail at stephenbrearley.name
Sat Mar 30 11:15:20 PDT 2013
Hi Markus
Yes, I am executing it from the GUI, but I also tried it from the Command
Console and got the same result.
Not understanding why it isn't working. As I'd suspected, you have not made
any changes to this module.
Thanks
  Stephen
-----Original Message-----
From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of
Markus Neteler
Sent: 30 March 2013 18:09
To: Stephen Brearley
Cc: GRASS user list
Subject: Re: [GRASS-user] r.out.xyz: Output error
On Sat, Mar 30, 2013 at 6:41 PM, Stephen Brearley
<mail at stephenbrearley.name> wrote:
>   r.out.xyz input=elev_ned_30m at PERMANENT
> output=D:\_SDB\GIS_DataBase\Grass\_Demo\Demo_locations\nc_spm_08\PERMA
> NENT\elev_ned_30m_xyz2
>   'output' is not recognized as an internal or external command,
> operable program or batch file.
To me it looks as if there is a linebreak before the output parameter. How
do you call r.out.xyz - in a scripts?
> I believe this is a 'basic' feature that is unlikely to have been changed.
Right, the output parameter is the same
http://grass.osgeo.org/grass70/manuals/r.out.xyz.html
Changed parameters are listed here:
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Rastermodulechanges
> Has it not been implemented yet, or should I be sticking with 6.4.2?
Please let us know how you execute above command.
Apparently not from the GUI.
Markus
