[GRASS-user] Rendering labels in GRASS Cartographic Composer from vector layer
Anna Kratochvílová kratochanna at gmail.com
Sun May 5 08:00:13 PDT 2013
On Sun, May 5, 2013 at 1:01 PM, Hamish <hamish_b at yahoo.com> wrote:
> Richard wrote:
> > I've run v.labels with font Helvetica and inserted Helvetica
> > in psmap file, and also tried changing fontsize in psmap file.
> > I also tried with a projected map layer, but still cannot see
> > the labels in the Map Composer...
> I think it's simply a matter of the composer not knowing anything
> about labels (yet). It still doesn't know about all the things
> that the ps.map back-end can do. But you don't need the composer
> to render, just run ps.map manually with your .psmap input rules
> file.
> I recently added support for labels in composer in grass 7 (Add
overlays -> Add labels). However I somehow overlooked the font option, so
it's not yet supported.
Anna
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130505/7f37b805/attachment-0001.html>
