[GRASS-user] r.resamp.rst - ERROR: Input window changed while maps are open for read.
Pietro
peter.zamb at gmail.com
Mon May 6 03:49:54 PDT 2013
Dear all,
I'm trying to use r.resamp.rst in GRASS7, I would like to interpolate
a map from a resolution of 1m to a resolution of 0.25.
I'm working with the following region:
GRASS 7.0.svn (edi):~ > g.region -p
projection: 99 (Transverse Mercator)
zone: 0
datum: osgb36
ellipsoid: airy
north: 674050
south: 673911
west: 325025
east: 325233
nsres: 1
ewres: 1
rows: 139
cols: 208
cells: 28912
Now if I try to run the following command I got:
GRASS 7.0.svn (edi):~ > r.resamp.rst input=diff ew_res=0.25 nsres=0.25
elev=diff_overl3_ten40 overlap=3 tension=40.
ERROR: Input window changed while maps are open for read. Map name <diff>
If I change the region to the resolution 0.25 I still got the same error:
GRASS 7.0.svn (edi):~ > g.region res=0.25 -p
zone: 0
datum: osgb36
ellipsoid: airy
north: 674050
south: 673911
west: 325025
east: 325233
nsres: 0.25
ewres: 0.25
rows: 556
cols: 832
cells: 462592
ERROR: Input map resolution differs from current region resolution!
the map diff is a FCELL map
GRASS 7.0.svn (edi):~ > r.info diff -g
north=680000
south=650000
east=340000
west=310000
nsres=1
ewres=1
rows=30000
cols=30000
cells=900000000
datatype=FCELL
What did I do wrong?
Any hints?
Pietro
