[GRASS-user] Query: number of 'areas' reported in v.build output does not necessarily represent different geographical areas
Markus Metz
markus.metz.giswork at gmail.com
Fri May 10 00:11:09 PDT 2013
On Fri, May 10, 2013 at 8:14 AM, RichardC <richtcooper at hotmail.com> wrote:
> I should rephrase my question, as Markus indicated that GRASS doesn't have
> tools to resolve:
You could try a dissolve:
v.category op=add cat=1 step=0 type=centroid layer=3
v.extract -d layer=3 type=area
optionally add new categories as unique ids to layer 1:
v.category op=del cat=-1 step=0 type=centroid layer=1
v.category op=add cat=1 step=1 type=centroid layer=1
HTH,
Markus M
> Is there any automated way outside GRASS (if not within) of removing the
> overlaps, as they appear quite extensive?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Query-number-of-areas-reported-in-v-build-output-does-not-necessarily-represent-different-geographics-tp5052007p5052463.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
