[GRASS-user] ERROR: Bytes do not match file size with r.in.bin (but file size is correct!!)
Ludovico Nicotina Ludovico.Nicotina at rms.com
Fri May 10 01:40:58 PDT 2013
Great thanks for your explanations! Looks like the quickest fix is splitting the grid into 2 smaller ones...and wait for the fix. Glad to help in solving pending issues.
Thanks,
Ludovico
-----Original Message-----
Sent: 10 May 2013 02:49
To: Ludovico Nicotina
Cc: GRASS user list
Subject: RE: [GRASS-user] ERROR: Bytes do not match file size with r.in.bin (but file size is correct!!)
>> G6> r.in.bin -f input=lfs_test.bin output=outputmap bytes=4 \
>>       n=51:05:20.4N s=41:21:50.4N w=5:08:31.2W e=9:33:36E \
>>       r=19450 c=29404 anull=-9999.0
>> WARNING: File Size -2007336096 ... Total Bytes 2287631200
Ludovico wrote:
> In my case the problem is not the fortran record markers, indeed the
> files are exactly the size they are supposed to be.
Hi, I just tested, it's still a bug in 6.4.3svn and devbr6.
filed as  https://trac.osgeo.org/grass/ticket/1971
It does import ok in GRASS 7; the r.in.bin module is essentially the same, the difference is that GRASS 6's G_ftell() function returns plain integer instead of off_t, and GRASS 7 defines
  LFS_CFLAGS = -D_FILE_OFFSET_BITS=64
so the PRI_OFF_T test in gis.h gets set to "lld", but GRASS 6 doesn't so the error message format gets set to "ld".
> PS. Hamish I will probably switch to 6.4.3rc3 anyway, would this
> solve the problem automatically in your opinion?
partly I'm just fishing for testers :), I hope we can commit a fix
for this very soon, but for now you could always build the GRASS 7
development code, import the raster map, and then fall back to the
stable version to work with it.
thanks for reporting it,
Hamish
This message and any attachments contain information that may be RMS Inc. confidential and/or privileged.  If you are not the intended recipient (or authorized to receive for the intended recipient), and have received this message in error, any use, disclosure or distribution is strictly prohibited.   If you have received this message in error, please notify the sender immediately by replying to the e-mail and permanently deleting the message from your computer and/or storage system.
