[GRASS-user] Query: number of 'areas' reported in v.build output does not necessarily represent different geographical areas
RichardC richtcooper at hotmail.com
Fri May 10 03:52:13 PDT 2013
Hi Markus,
> I assume the global mangroves map should not have overlapping
> polygons, therefore as long as there are overlapping areas and/or the
> number of centroids is not equal to the number of input polygons, more
> cleaning is needed.
How critical is it that the number of input polygons = number of centroids?
For example, I've imported a a different shapefile with 6842 input polygons
and after importing (with 1e-12 snapping threshold) there are 6800
centroids. Further cleaning does not change the topology. Also can I ignore
the areas without centroids?
Number of nodes: 17265
Number of primitives: 20687
Number of points: 0
Number of lines: 0
Number of boundaries: 13887
Number of centroids: 6800
Number of areas: 10521
Number of isles: 7099
Number of areas without centroid: 3721
Would I be correct in saying that a layer is topologically correct and needs
no further cleaning provided, there are no (i.e, zero):
1. overlapping areas;
2. incorrect boundaries;
3. centroids outside area; and
4. duplicate centroids.
While:
5. areas without centroids can be ignored.
Many thanks, for your feedback.
Richard
View this message in context: http://osgeo-org.1560.x6.nabble.com/Query-number-of-areas-reported-in-v-build-output-does-not-necessarily-represent-different-geographics-tp5052007p5052530.html
Sent from the Grass - Users mailing list archive at Nabble.com.
