[GRASS-user] EPSG code spearfish dataset
Hamish hamish_b at yahoo.com
Thu May 16 04:57:57 PDT 2013
Johannes wrote:
> is there any EPSG code defined for the projection of the
> spearfish sample dataset?
> Or a EPSG code that is close to the projecton? I am just
> asking as there is a code provided for the NC-dataset but
> not for the Spearfish.
It is UTM zone 13 N, using the NAD27 datum. The ellipsoid is
clark66 and the datum transform grid is "conus".
The matching epsg code is #26713, although that code does not
specify which datum transform terms/grid should be used.
As far as I know the Spearfish dataset predates the EPSG
list, or at least they are about the same age.
Hamish
