[GRASS-user] Fwd: Airborne LiDAR data strip adjustment
Adrian Kirilov
kirilov.adrian at gmail.com
Fri May 17 05:21:49 PDT 2013
Hello to all,
Ok, I just found out that this is not necessary! My data are already
pre-processed, so it's applied strip adjustment. I have to divide it into
subsets and merge the data, because now it's in form of strips. I guess the
right method is using 'g.region' when importing the strips and then combine
them by exporting a vector map with 'v.out.ascii' and re-import the whole
map and interpolating a surface. What do you think?
Greetings,
Adrian Kirilov
---------- Forwarded message ----------
Date: Fri, May 17, 2013 at 7:22 AM
Subject: Airborne LiDAR data strip adjustment
To: GRASS user list <grass-user at lists.osgeo.org>
Hello to all using GRASS,
I received ALS data, which is with overlapping strips in both
directions, east-west and north-south. Is it available some algorithm to do
a strip adjustment in GRASS GIS or any other software, so I can build
cleared DEM (without overlapping data)?
Greetings,
Adrian Kirilov
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20130517/d8740980/attachment-0001.html>
