[GRASS-user] g.extension error installing install r.hazard.flood
RichardC
richtcooper at hotmail.com
Fri May 17 07:09:35 PDT 2013
I resolved running r.fuzzy.logic by setting the GRASS_ADDON_PATH
1. Set in terminal before starting GRASS;
$ GRASS_ADDON_PATH=/home/rcooper/.grass6/addons/bin
export GRASS_ADDON_PATH
2. r.fuzzy.logic can now be run from the GRASS Layer Manager via the Command
Console:
r.fuzzy.logic
View this message in context: http://osgeo-org.1560.x6.nabble.com/g-extension-error-installing-install-r-hazard-flood-tp5053923p5054013.html
Sent from the Grass - Users mailing list archive at Nabble.com.
