[GRASS-user] Getting Started with GRASS Python Scripts
Martin Lacayo mlacayo at stanford.edu
Thu May 23 15:37:58 PDT 2013
I think I have now figured out most of the answers to my question, but
I am still wondering about some file management.
Is the following command a "normal" way to make a location with a
projection from a georeferenced file:
 g.proj -c georef=/home/user/raster.tif location=example
Is there a command to delete a location?
I found g.mremove, but that seems to remove data, not locations.
Thank you,
Martin
On Thu, May 23, 2013 at 3:02 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Thu, 23 May 2013, Martin Lacayo wrote:
>> Thank you. Yes, that does help. I hadn't realized that in this case
>> database was essentially synonymous with user directory. Several things
>> have now clicked into place.
> Martin,
>   Yeah, it ain't intuitive. :-)
>   Took me a while to get my head around the GRASS structure, but that was
> with 4.0. It's sunk in over the years since then.
> Rich
> Richard B. Shepard, Ph.D.          |      Have knowledge, will travel.
> Applied Ecosystem Services, Inc.   |
> <http://www.appl-ecosys.com>     Voice: 503-667-4517      Fax: 503-667-8863
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
