[GRASS-user] reset zone in projection settings
Nikos Alexandris nik at nikosalexandris.net
Tue May 28 17:33:10 PDT 2013
Janet Choate wrote:
> > Hello GRASS users,i have reset my locations projection settings - for the
> > purpose of updating the zone from 0 to 11.  however, after running
> > g.setproj to make this change, g.region -p still shows the zone set to 0.
> >  is there another command that i should use, or a series of commands that
> > need to be executed to make this change?
> > any guidance would be appreciated.
Paul Kelly wrote:
> One possibility is that g.setproj has correctly updated your default
> region, but you now need to reset your current region to the (new)
> default. You can do this by running:
> g.region -d
> Does that help?
Janet, Paul, what about
g.proj -c
without specifying a new "location="? Isn't this another option?
Best, Nikos
