[GRASS-user] trouble with r.in.gdal to georeference a NetCDF file
Anna Petrášová kratochanna at gmail.com
Mon Nov 11 21:21:28 PST 2013
On Mon, Nov 11, 2013 at 11:37 PM, Lee Eddington
<lee.w.eddington at gmail.com>wrote:
> I'm trying to import a NetCDF file from the WRF weather forecast model
> with r.in.gdal, but I can't get it to georeference.  Instead I end up with
> a x,y coordinate system of rows and columns.  The file georeferences fine
> in a number of other weather graphics programs.  I tried to follow the
> directions at:
> http://www.gdal.org/frmt_netcdf.html
> but when I run gdalinfo I get the following:
> $ gdalinfo geo_em.d03.nc
> Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
> Driver: netCDF/Network Common Data Format
> Files: geo_em.d03.nc
> Size is 512, 512
> Coordinate System is `'
> Metadata:
>   NC_GLOBAL#BOTTOM-TOP_GRID_DIMENSION=0
>   NC_GLOBAL#CEN_LAT=-8.4095154
>   NC_GLOBAL#CEN_LON=115.02
>   NC_GLOBAL#corner_lats={ -10.454437, -6.3537445, -6.3537445, -10.454437,
> -10.454437, -6.3537445, -6.3537445, -10.454437, -10.46785, -6.3401871,
> -6.3401871, -10.46785, -10.46785, -6.3401871, -6.3401871, -10.46785 }
>   NC_GLOBAL#corner_lons={ 112.3332, 112.3332, 117.70679, 117.70679,
> 112.31956, 112.31956, 117.72044, 117.72044, 112.3332, 112.3332, 117.70679,
> 117.70679, 112.31956, 112.31956, 117.72044, 117.72044 }
>   NC_GLOBAL#DX=3000
>   NC_GLOBAL#DY=3000
>   NC_GLOBAL#DYN_OPT=2
>   NC_GLOBAL#FLAG_MF_XY=1
>   NC_GLOBAL#grid_id=3
>   NC_GLOBAL#GRIDTYPE=C
>   NC_GLOBAL#i_parent_end=99
>   NC_GLOBAL#i_parent_start=34
>   NC_GLOBAL#ISICE=24
>   NC_GLOBAL#ISLAKE=-1
>   NC_GLOBAL#ISOILWATER=14
>   NC_GLOBAL#ISURBAN=1
>   NC_GLOBAL#ISWATER=16
>   NC_GLOBAL#j_parent_end=84
>   NC_GLOBAL#j_parent_start=34
>   NC_GLOBAL#MAP_PROJ=3
>   NC_GLOBAL#MMINLU=USGS
>   NC_GLOBAL#MOAD_CEN_LAT=-8.4095078
>   NC_GLOBAL#NUM_LAND_CAT=24
>   NC_GLOBAL#parent_grid_ratio=3
>   NC_GLOBAL#parent_id=2
>   NC_GLOBAL#POLE_LAT=90
>   NC_GLOBAL#POLE_LON=0
>   NC_GLOBAL#SIMULATION_START_DATE=0000-00-00_00:00:00
>   NC_GLOBAL#SOUTH-NORTH_GRID_DIMENSION=154
>   NC_GLOBAL#SOUTH-NORTH_PATCH_END_STAG=154
>   NC_GLOBAL#SOUTH-NORTH_PATCH_END_UNSTAG=153
>   NC_GLOBAL#SOUTH-NORTH_PATCH_START_STAG=1
>   NC_GLOBAL#SOUTH-NORTH_PATCH_START_UNSTAG=1
>   NC_GLOBAL#sr_x=1
>   NC_GLOBAL#sr_y=1
>   NC_GLOBAL#STAND_LON=115.02
>   NC_GLOBAL#TITLE=OUTPUT FROM GEOGRID V3.4
>   NC_GLOBAL#TRUELAT1=-8.4095001
>   NC_GLOBAL#TRUELAT2=0
>   NC_GLOBAL#WEST-EAST_GRID_DIMENSION=199
>   NC_GLOBAL#WEST-EAST_PATCH_END_STAG=199
>   NC_GLOBAL#WEST-EAST_PATCH_END_UNSTAG=198
>   NC_GLOBAL#WEST-EAST_PATCH_START_STAG=1
>   NC_GLOBAL#WEST-EAST_PATCH_START_UNSTAG=1
> Subdatasets:
>   SUBDATASET_1_NAME=NETCDF:"geo_em.d03.nc":Times
>   SUBDATASET_1_DESC=[1x19] Times (8-bit character)
>   SUBDATASET_2_NAME=NETCDF:"geo_em.d03.nc":XLAT_M
>   SUBDATASET_2_DESC=[1x153x198] XLAT_M (32-bit floating-point)
>   SUBDATASET_3_NAME=NETCDF:"geo_em.d03.nc":XLONG_M
>   SUBDATASET_3_DESC=[1x153x198] XLONG_M (32-bit floating-point)
>   SUBDATASET_4_NAME=NETCDF:"geo_em.d03.nc":XLAT_V
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,  512.0)
> Upper Right (  512.0,    0.0)
> Lower Right (  512.0,  512.0)
> Center      (  256.0,  256.0)
> The warning -
> leads me to believe that all the projection info is not being recognized,
> but I'm not sure why.  Is it possible that GDAL wasn't compiled with libnetcdf?
>  But if that's the case I would think that gdalinfo wouldn't work at all.
> I've imported the data into GRASS using:
> r.in.gdal input="NETCDF:geo_em.d03.nc:HGT_M" output="d03_HGT_M"
> location="bali_d03"
> to create a new location.
> I also created a location with the Mercator projection of the data and
> tried importing using:
> r.in.gdal -o input="NETCDF:grassdata/bali/geo_em.d03.nc:HGT_M"
> output="d03_HGT_M"
> but as far as I can tell still get an x,y row,column coordinate system.
> I also have the lat and lon of each cell.  Is there anyway to georeference
> using that data?
try to create a WGS84 latitude-longitude projection (EPSG 4326) and then
run r.in.gdal with -o flag. At least that worked for me and I had similar
gdalinfo output.
Anna
> Thanks,
> Lee
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131112/851220e4/attachment-0001.html>
