[GRASS-user] trouble with r.in.gdal to georeference a NetCDF file
Anna Petrášová kratochanna at gmail.com
Tue Nov 12 05:28:56 PST 2013
On Tue, Nov 12, 2013 at 12:55 AM, Lee Eddington
<lee.w.eddington at gmail.com>wrote:
> Anna,
> I tried your suggestion, but now I'm unable to import the data.  Here's
> some output showing the region and the error messages:
What does the gdalinfo says about the subdataset?
gdalinfo NETCDF:geo_em.d03.nc:HGT_M
> GRASS 6.4.3 (bali_d03_ll):~ > g.proj -p
> -PROJ_INFO-------------------------------------------------
> proj       : ll
> datum      : wgs84
> ellps      : wgs84
> no_defs    : defined
> towgs84    : 0.000,0.000,0.000
> -PROJ_UNITS------------------------------------------------
> unit       : degree
> units      : degrees
> meters     : 1.0
> GRASS 6.4.3 (bali_d03_ll):~ > g.region -p
> projection: 3 (Latitude-Longitude)
> zone:       0
> datum:      wgs84
> ellipsoid:  wgs84
> north:      6:19:40.44S
> south:      10:27:59.04S
> west:       112:19:46.2E
> east:       117:43:20.64E
> nsres:      0:01:36.12
> ewres:      0:01:37.56
> rows:       155
> cols:       199
> cells:      30845
> GRASS 6.4.3 (bali_d03_ll):~ > r.in.gdal -o
> input="NETCDF:grassdata/bali/geo_em.d03.nc:HGT_M" output="d03_HGT_M"
> Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
> WARNING: Over-riding projection check
> WARNING: G_set_window(): Illegal latitude for North
> On Mon, Nov 11, 2013 at 9:21 PM, Anna Petrášová <kratochanna at gmail.com>wrote:
>> Hi,
>> On Mon, Nov 11, 2013 at 11:37 PM, Lee Eddington <
>> lee.w.eddington at gmail.com> wrote:
>>> I'm trying to import a NetCDF file from the WRF weather forecast model
>>> with r.in.gdal, but I can't get it to georeference.  Instead I end up with
>>> a x,y coordinate system of rows and columns.  The file georeferences fine
>>> in a number of other weather graphics programs.  I tried to follow the
>>> directions at:
>>> http://www.gdal.org/frmt_netcdf.html
>>> but when I run gdalinfo I get the following:
>>> $ gdalinfo geo_em.d03.nc
>>> Driver: netCDF/Network Common Data Format
>>> Files: geo_em.d03.nc
>>> Size is 512, 512
>>> Coordinate System is `'
>>> Metadata:
>>>   NC_GLOBAL#BOTTOM-TOP_GRID_DIMENSION=0
>>>   NC_GLOBAL#CEN_LAT=-8.4095154
>>>   NC_GLOBAL#CEN_LON=115.02
>>>   NC_GLOBAL#corner_lats={ -10.454437, -6.3537445, -6.3537445,
>>> -10.454437, -10.454437, -6.3537445, -6.3537445, -10.454437, -10.46785,
>>> -6.3401871, -6.3401871, -10.46785, -10.46785, -6.3401871, -6.3401871,
>>> -10.46785 }
>>>   NC_GLOBAL#corner_lons={ 112.3332, 112.3332, 117.70679, 117.70679,
>>> 112.31956, 112.31956, 117.72044, 117.72044, 112.3332, 112.3332, 117.70679,
>>> 117.70679, 112.31956, 112.31956, 117.72044, 117.72044 }
>>>   NC_GLOBAL#DX=3000
>>>   NC_GLOBAL#DY=3000
>>>   NC_GLOBAL#DYN_OPT=2
>>>   NC_GLOBAL#FLAG_MF_XY=1
>>>   NC_GLOBAL#grid_id=3
>>>   NC_GLOBAL#GRIDTYPE=C
>>>   NC_GLOBAL#i_parent_end=99
>>>   NC_GLOBAL#i_parent_start=34
>>>   NC_GLOBAL#ISICE=24
>>>   NC_GLOBAL#ISLAKE=-1
>>>   NC_GLOBAL#ISOILWATER=14
>>>   NC_GLOBAL#ISURBAN=1
>>>   NC_GLOBAL#ISWATER=16
>>>   NC_GLOBAL#j_parent_end=84
>>>   NC_GLOBAL#j_parent_start=34
>>>   NC_GLOBAL#MAP_PROJ=3
>>>   NC_GLOBAL#MMINLU=USGS
>>>   NC_GLOBAL#MOAD_CEN_LAT=-8.4095078
>>>   NC_GLOBAL#NUM_LAND_CAT=24
>>>   NC_GLOBAL#parent_grid_ratio=3
>>>   NC_GLOBAL#parent_id=2
>>>   NC_GLOBAL#POLE_LAT=90
>>>   NC_GLOBAL#POLE_LON=0
>>>   NC_GLOBAL#SIMULATION_START_DATE=0000-00-00_00:00:00
>>>   NC_GLOBAL#SOUTH-NORTH_GRID_DIMENSION=154
>>>   NC_GLOBAL#SOUTH-NORTH_PATCH_END_STAG=154
>>>   NC_GLOBAL#SOUTH-NORTH_PATCH_END_UNSTAG=153
>>>   NC_GLOBAL#SOUTH-NORTH_PATCH_START_STAG=1
>>>   NC_GLOBAL#SOUTH-NORTH_PATCH_START_UNSTAG=1
>>>   NC_GLOBAL#sr_x=1
>>>   NC_GLOBAL#sr_y=1
>>>   NC_GLOBAL#STAND_LON=115.02
>>>   NC_GLOBAL#TITLE=OUTPUT FROM GEOGRID V3.4
>>>   NC_GLOBAL#TRUELAT1=-8.4095001
>>>   NC_GLOBAL#TRUELAT2=0
>>>   NC_GLOBAL#WEST-EAST_GRID_DIMENSION=199
>>>   NC_GLOBAL#WEST-EAST_PATCH_END_STAG=199
>>>   NC_GLOBAL#WEST-EAST_PATCH_END_UNSTAG=198
>>>   NC_GLOBAL#WEST-EAST_PATCH_START_STAG=1
>>>   NC_GLOBAL#WEST-EAST_PATCH_START_UNSTAG=1
>>> Subdatasets:
>>>   SUBDATASET_1_NAME=NETCDF:"geo_em.d03.nc":Times
>>>   SUBDATASET_1_DESC=[1x19] Times (8-bit character)
>>>   SUBDATASET_2_NAME=NETCDF:"geo_em.d03.nc":XLAT_M
>>>   SUBDATASET_2_DESC=[1x153x198] XLAT_M (32-bit floating-point)
>>>   SUBDATASET_3_NAME=NETCDF:"geo_em.d03.nc":XLONG_M
>>>   SUBDATASET_3_DESC=[1x153x198] XLONG_M (32-bit floating-point)
>>>   SUBDATASET_4_NAME=NETCDF:"geo_em.d03.nc":XLAT_V
>>> Corner Coordinates:
>>> Upper Left  (    0.0,    0.0)
>>> Lower Left  (    0.0,  512.0)
>>> Upper Right (  512.0,    0.0)
>>> Lower Right (  512.0,  512.0)
>>> Center      (  256.0,  256.0)
>>> The warning -
>>> leads me to believe that all the projection info is not being
>>> recognized, but I'm not sure why.  Is it possible that GDAL wasn't compiled
>>> with libnetcdf?  But if that's the case I would think that gdalinfo
>>> wouldn't work at all.
>>> I've imported the data into GRASS using:
>>> r.in.gdal input="NETCDF:geo_em.d03.nc:HGT_M" output="d03_HGT_M"
>>> location="bali_d03"
>>> to create a new location.
>>> I also created a location with the Mercator projection of the data and
>>> tried importing using:
>>> r.in.gdal -o input="NETCDF:grassdata/bali/geo_em.d03.nc:HGT_M"
>>> output="d03_HGT_M"
>>> but as far as I can tell still get an x,y row,column coordinate system.
>>> I also have the lat and lon of each cell.  Is there anyway to
>>> georeference using that data?
>> try to create a WGS84 latitude-longitude projection (EPSG 4326) and then
>> run r.in.gdal with -o flag. At least that worked for me and I had similar
>> gdalinfo output.
>> Anna
>>>  Thanks,
>>> Lee
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131112/9f6e7e30/attachment-0001.html>
