[GRASS-user] trouble with r.in.gdal to georeference a NetCDF file
Lee Eddington lee.w.eddington at gmail.com
Sat Nov 23 00:58:51 PST 2013
Markus,
I tried and got the following:
lees-mbp:bali Lee$ gdalwarp test.nc test.tif
Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
Input file test.nc has no raster bands.
I've attached the file in case you'd be willing to see what you can do with
it.
Thanks,
Lee
On Sun, Nov 17, 2013 at 1:29 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Wed, Nov 13, 2013 at 11:58 PM, Lee Eddington
> <lee.w.eddington at gmail.com> wrote:
> > Markus,
> > Could you provide me an example of using gdalwarp converting a NetCDF
> field
> > to a GeoTIFF?
> I often due multiple runs here. Initially
> gdalwarp thefile.nc thefile.tif
> then I check if the target resolution is as expected (if not, see the
> -tr parameter) and so on.
> Here is an older blog page which may be of interest:
> http://blog.neteler.org/gdal-raster-data-tips-and-tricks/
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131123/4f5420cb/attachment-0001.html>
Type: application/x-netcdf
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131123/4f5420cb/attachment-0001.nc>
