[GRASS-user] trouble with r.in.gdal to georeference a NetCDF file
Lee Eddington
lee.w.eddington at gmail.com
Sat Nov 23 21:14:51 PST 2013
Markus,
I can read a raster from the file into GRASS using:
r.in.gdal input="NETCDF:test.nc:V10" output="V10_test3"
and I get the following:
GRASS 6.4.3 (bali_d03):~ > r.info V10_test3
| Layer: V10_test3 Date: Sat Nov 23 20:56:28 2013 |
| Mapset: PERMANENT Login of Creator: Lee |
| DataBase: /Users/Lee/grassdata |
| Title: ( V10_test3 ) |
| Timestamp: none |
| Type of Map: raster Number of Categories: 255 |
| Data Type: FCELL |
| Rows: 153 |
| Columns: 198 |
| Total Cells: 30294 |
| Projection: x,y |
| N: 153 S: 0 Res: 1 |
| E: 198 W: 0 Res: 1 |
| Range of data: min = -12.64637 max = 7.255654 |
| Data Description: |
| generated by r.in.gdal |
| Comments: |
| r.in.gdal input="NETCDF:test.nc:V10" output="V10_test3" |
gdalinfo on test.nc gives the following (I’ve stripped out a lot of the metadata, but left the info the describes the Mercator projection):
lees-mbp:bali Lee$ gdalinfo test.nc
Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
Driver: netCDF/Network Common Data Format
Files: test.nc
Size is 512, 512
Coordinate System is `'
Metadata:
NC_GLOBAL#CEN_LAT=-8.4095154
NC_GLOBAL#CEN_LON=115.02
NC_GLOBAL#MAP_PROJ=3
NC_GLOBAL#STAND_LON=115.02
NC_GLOBAL#TRUELAT1=-8.4095001
NC_GLOBAL#TRUELAT2=0
Subdatasets:
SUBDATASET_1_NAME=NETCDF:"test.nc":U10
SUBDATASET_1_DESC=[1x153x198] U10 (32-bit floating-point)
SUBDATASET_2_NAME=NETCDF:"test.nc":V10
SUBDATASET_2_DESC=[1x153x198] V10 (32-bit floating-point)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
I can display the data in GRASS (see attachment).
I have the latitude and longitude values for every raster point from another file and can read them into collocated rasters. I was able to interactively georectify the raster, but my goal is produce automated scripts and it doesn’t appear that there’s a way to automate the georectify process (please correct me if I’m wrong). I tried using g.setproj to change the projection as I know what it is, but it wouldn’t allow me to because the current projection is x,y.
Thanks for sticking with me on this,
Lee
On Nov 23, 2013, at 7:43 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Lee,
> I am not much familiar with non-map netCDF files. I do not know how to
> deal with this specific file...
> Let's hope that an answer from the community arrives. To me it doesn't
> look like a file containing maps.
> Best
> Markus
> On Sat, Nov 23, 2013 at 9:58 AM, Lee Eddington
> <lee.w.eddington at gmail.com> wrote:
>> Markus,
>> I tried and got the following:
>> lees-mbp:bali Lee$ gdalwarp test.nc test.tif
>> Input file test.nc has no raster bands.
>> I've attached the file in case you'd be willing to see what you can do with
>> it.
>> Thanks,
>> Lee
>> On Sun, Nov 17, 2013 at 1:29 AM, Markus Neteler <neteler at osgeo.org> wrote:
>>> On Wed, Nov 13, 2013 at 11:58 PM, Lee Eddington
>>>> Markus,
>>>> Could you provide me an example of using gdalwarp converting a NetCDF
>>>> field
>>>> to a GeoTIFF?
>>> I often due multiple runs here. Initially
>>> gdalwarp thefile.nc thefile.tif
>>> then I check if the target resolution is as expected (if not, see the
>>> -tr parameter) and so on.
>>> Here is an older blog page which may be of interest:
>>> http://blog.neteler.org/gdal-raster-data-tips-and-tricks/
>>> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131123/bac9c343/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20131123/bac9c343/attachment-0001.png>
