[GRASS-user] multiple polygons with same cat
Dave Roberts
dvrbts at ecology.msu.montana.edu
Tue Nov 26 08:57:04 PST 2013
Markus,
Thanks a mill! I'll try that when I get back to that machine.
I really appreciate you time end expertise. You're a scholar and a
gentleman.
Dave
On 11/26/2013 08:48 AM, Markus Metz wrote:
> On Tue, Nov 26, 2013 at 4:34 PM, Dave Roberts
> <dvrbts at ecology.msu.montana.edu> wrote:
>>> I would suggest to run
>>> v.category inp=geo type=centroid out=new_geo op=add layer=2 --o
>> Thanks Markus! Now I'm getting somewhere. v.info shows geo and new_geo in
>> perfect correspondence for areas, islands, boundaries, etc.
>> d.what.vect shows new_geo with the original data in layer 1 and the new data
>> in layer 2. v.to.db successfully transferred the centroids (coor) and area
>> to layer 2. However, I still don't see how to get the surficial geology
>> column (surgeo) out of layer 1 into layer 2 without a join item. I know I'm
>> missing something simple, but v.to.db just seems to allow a restricted set
>> of values for option.
> v.to.db map=new_geo layer=2 column=surgeo option=query qlayer=1 qcolumn=surgeo
> In this example, the column surgeo in layer 2 must exist and must be
> of the same type like the column surgeo in layer 1.
> Markus M
>> Thanks, Dave
>> David W. Roberts office 406-994-4548
>> Professor and Head FAX 406-994-3190
>> Department of Ecology email droberts at montana.edu
>> Montana State University
>> Bozeman, MT 59717-3460
